Are you a piano tuner by any chance?
Also confirm that after disconnecting L/N/E at the CU, the MCB can be reset. If not then you have a damaged MCB as well which will need replacing.I am going to start disconnecting lives and neutrals at the ceiling roses until it will reset.
Lighting circuits are wired in a radial format in domestic settings so when you get to the faulty fitting/dodgy connection, you will have located your fault as your MCB will trip.Any way I seem to be getting some where by disconnecting lives. So far I have 2 fluorescent units working a one bulb!!
Ken: I've read this carefully about ten times, and it doesn't seem to make sense as you describe it.OK, the fault appears to be the live feed from lounge wall switch to the lounge light ceiling rose. If I leave this disconnected at the switch all lights to this point work without tripping the mcb. If I connect it and disconnect it at the rose it trips the mcb. What is the easiest and right way to replace this twin core and earth cable?
