Lincrusta wallpaper
13 Jun 2005
Yorkshire
Anyone out there with experience of hanging Lincrusta wallpaper?
Have just bought 2 rolls of Adam frieze and the special adhesive but am not sure how to go about this. I want to hang it above the picture rail in my kitchen to give it that authentic victorian look. Is it just the normal case of slapping the glue to the paper and hangin onto the wall or is there somethings I need to be aware of:?: :?: :?:
If it is true lincrusta you won't be able to roll it, I suspect that it is a modern Lincrusta effect, have you looked on the back of the lable as most wallpapers have the hanging instructions printed there.
Usually just apply the paste to the back of paper leave to rest for 10mins then hang as normal paper.
Jason
Somethings you need to be aware of?....yeh..you could say....
Firstly....what are your walls like?
Make sure your walls are in good condition before you start..the ideal surface is lining paper, this will help maximise adhesion..stick it on well using a pre mixed adhesive
If your confedent and good with a knife, try and cut the lengths first on a paste table.....this will avoid you having to cut it when in position and running the risk of snapping the relief (which can be repaired with polyfilla)
Sponge the back of the paper with warm water and leave it to soak for half an hour...do a couple of bits at a time and leave them back to back...this will stop the water drying out to soon.
Remove surplus water from the backs after soaking and apply the glue.
Talking of which....make sure you give it a good stir.
Use a clean short pile roller to flatten the paper out not a papering brush....you will find this easier and it will help remove all trapped air.
In corners, cut the paper tight into internal corners...dont attempt to take it round of leave half an inch or so on the return wall.
As Jason said, read the intructions, thats vital with Lincrusta, use a Stanley knife as opposed to the snap of blade variety, and have plenty of spare blades at hand.
Leave for at least 24 hours before you attempt to decorate
Give the surface a good wipe over with white spirit to neutralise any Linseed oil which may be on the surface before you paint it
Id go for an oil based system.....failing that water based is ok.....but use an acrylic primer first...dont try and hump one coat of paint on...its far better to give it two or three thinner ones
Above all......take your time....this stuff isnt two bob blown vinyl.. most decorators cant or wont hang it.
Hope that helps.
Hey!
Just been reading about your problems hanging Lincrusta - I've been specialising in decorating with Lincrusta for some time now, and just wanted to point something out.
One of the chaps above mentioned to repair joints with polyfilla, please don't, Lincrusta is an oil based product and will not take kindly to it... Linseed oil putty is recommended.
The best method is to rub joints down with an old piece od wet and dry paper (wash down with white spirits), prime appropriately, then fill with the putty - this way the primer often does the filling for you.
Hope this helps... anyone else need Lincrusta advice please send me an email at [email protected]
MJG
Pretty much as Zampa says. Lincrusta is basically linseed oil putty stuck to lining paper. It will not bend around a corner so every piece has to be cut dry and to size. It has little or no exspansion. You cannot really fold it like traditional wallpaper and each length has to soak on the board. Not a quick job but the resullts are worth it. I was hanging this 35 years ago when i was an apprentice with my father. There used to be some great patterns but a lot of them have now been discontinued.
Good tips there MJ cheers..
I dont think I was clear about the filler though...I meant after it had been painted..not on the surface of the paper itself...as you correctly said it would be a problem if the linseed oil soaked into the filler
