Recently had a window replaced on the ground floor with french doors size 3050mm x 2100mm. Apparently no lintel was found?
Now wish to have window above replaced with inward french doors so wall has to be removed with window above and lintel and french doors put in place
Seem to be getting conflicting information as to what lintel should be put in
current window above which is to be removed is 1900w and has a lintel above
standard cavity wall construction
51 courses of bricks above lower french doors
How is best to put lintel in now before window above is removed and
french doors put in place with Juliet balcony?
Thankyou
Thankyou
