I'm having an extension built, but someone has put the idea forward about making the front room bigger, as the garage was going to be pretty big to start with.
I've attached a pdf with the proposed position of the rsj shown with red dashed lines, any advice and suggestions, for something of this lengh? Nibs, etc
Also on the left hand side is the opening for the kitchen, I wanted to fit a catnic or other lintel for this, but may have to use an rsj, problem I had also was the staircase landing protrudes into the kitchen ceiling at a lower point and the joists for this are supported in the wall I'm removing, so I'd have to use some form of joist hanger also...
Any suggestions on this one too?
http://dl.dropbox.com/u/59107343/lintelexample.pdf
