if the glass does not press tightly against the glazing bars, you might try drilling through the central bar.
If it does, you could groove the bar just enough to permit air to pass.
There are defogging systems used in the US where they drill the outer pane with a diamond bit, and insert insect-proof breathable plugs. This seems to be done on DG shop windows, where a new unit would be particularly expensive.
Breathing to the outside is key. Expansion and contraction as the air in the cavity warms and cools is all it needs. I have done a few. I still have one that I did over 20 years ago and it does not mist. I have not opened it since the day I did it.
