This morning changing a hand drier. Turned OFF spur, cutting decorators caulk with knife, and bang!
That explains the pop.....
Dare I observe that you appear to have plunged the blade of your Stanley knife into a safe zone created by the FCU, if not also by the dryer?This morning changing a hand drier. Turned OFF spur, cutting decorators caulk with knife, and bang!
You can observe![]()
Not expected though is it!
Actually didn't feel a thing, metal handle too. Quick pop, a few sparks, RCBO operated.
Dare I observe that you appear to have plunged the blade of your Stanley knife into a safe zone created by the FCU, if not also by the dryer?This morning changing a hand drier. Turned OFF spur, cutting decorators caulk with knife, and bang!![]()
Kind Regards, John
I wouldn't argue with what you say (I would very probably have been 'caught out', just as Lectrician was), but that doesn't make it 'right' to assume that it's safe to push a knife blade in there. As an electrician would understand more than most people, "a safe zone is a safe zone", and therefore should be regarded as a potential site of a hidden cable, even if one can question the wisdom of someone installing it like that!i would have thought any person in this situation would access the back in an identical or very similar way so the actual fault is the installers lack off intelligence in planning to allow access for maintainance and repair in a sensible and reasonable way ... but hay i am only a chippie what do i know![]()
I could be wrong but I suspect the installer of the drier just screwed it to the wall and then some decorator came along later and decided to caulk round it.i would have thought any person in this situation would access the back in an identical or very similar way so the actual fault is the installers lack off intelligence in planning to allow access for maintainance and repair in a sensible and reasonable way ... but hay i am only a chippie what do i know![]()
You are quite probably right, but the caulk is not really the underlying issue, since its presence does not alter the safe zone.I could be wrong but I suspect the installer of the drier just screwed it to the wall and then some decorator came along later and decided to caulk round it.
In a slightly different scenario, had that cable continued horizontally to the right of the dryer, someone who did not realise/understand/remember that the FCU created a safe zone might have drilled into the cable, a fair distance from the dryer (caulk or no caulk).
Kind Regards, John
Now, how are you going to repair that cable?![]()
