Live wire from old pump on vented to system boiler
22 Jul 2017
A couple of installers have mentioned this,
So going from vented system to system boiler WB 15i, possibly.
They tell me that they have to take a live from where the old pump would be removed to the new system boiler.
I don't understand this as I would have thought that when the microswitch opens and connects on the 2 port valve this would then turn the boiler on. Where does the pump come into the equation?
The WB 15I is a system boiler and the pump is built within the boiler and controlled by the boiler, do you mean the 15Ri ? If it is the Ri it is a heat only boiler and the external pump must be wired from the boiler for the pump over run function to work
No it is definitely a 15i system boiler.
So I presume that u just disconnect the old pump on the old vented system and the microswitch will turn the boiler on or the system boiler will sort out the start up itself
The Boiler needs a permanent live to run overheat protection when you or the thermostat switches it off.
Residual heat removal.
Sorry to be a bit thick but could u not take the permanent live from the main boiler switch on the wall and use the switched one from the zone valves? Currently my old vented boiler doesn't have pump overun so as u said before, just a switched live from zone valves.
Not sure what Jeff's response is, did I say something wrong,?
Ok, that's a relief,
I blame it all on these installers coming round to give me quotes for a system boiler from a vented system.
A couple have said , have to take a wire from the old pump (in the airing cupboard) back to the new boiler.
But looks like, switched live comes from the zone valves and permanent live can really come from a live near the boiler.
I knew that I should have been an electrician really.
Thanks to u and Ian
