Location of Consumer Unit.
We need a Hamer House of Horrors library
:shock:
EddieCurrent said:
Hello All,
Maybe the 'kitchen fitter' expects the electrician who does any work in this house to take the wall unit down when access is needed !!! :shock:
FFS.
Wonder if it was the same fitter who did this one? (its at the end of a 1000 wide corner unit)
I've seen one that was actually bricked up. You could get to it via a four-brick hole in the wall of the old coal shed, but you couldn't actually see it. The owners had to frequently reach in to reset a breaker they could only find by touch, because the KFs had overloaded it.
I have no idea why sparkies feel so strongly about KFs doing electrical work. :roll:
i had a some dodgy electrics when i moved in to my house .
1/ shower pull swich situated above shower unit over bath .
2/ fire place wall socket had bean moved out from wall , one of the brick wall tv unit thingies , cable from left hand double socket went to ceiling rose bolted to socket back box where they took a 6mm cable along along and up mantle piece through front of chimney breast out other side down pipe box to a double pole light switch output went to single socket with a plug in it for central heating pump.
there was another double socket within 12 inches of pump.
