Have just been to a Worcester 20/25 which ran fine and then locked out after about 5/6 minutes. There is a phial in front of the red expansion vessel and on my boiler which is the same the phial is under the expansion vessel. Any thoughts? Regards.
newoilman said:Have just been to a Worcester 20/25 which ran fine and then locked out after about 5/6 minutes. There is a phial in front of the red expansion vessel and on my boiler which is the same the phial is under the expansion vessel. Any thoughts? Regards.
newoilman said:Hi there, thanks for replies - the burners fires again when reset button is pressed, thought I would mention the phial as it is in a different place in my boiler. Could the phial detect heat from the red expansion vessel and lockout for safety? Any further thoughts? Cheers.![]()
newoilman said:Thinking back there was a click shorty before the lockout.
newoilman said:Thanks chr15 - presumably if this is the case the coil has started to break down and closing when it shouldn't.
newoilman said:When I went to this boiler it was very late in the day and I was not in a position to start to change the photocell/coil etc to try to rectify the problem that is why I thought the forum would be a good idea to see if anyone else had seen the same symptoms. I think I will replace the coil, clean the photocell and go from there. I really do appreciate help given as I am new to the job and on my own. I have done Oftec but this did not cover any fault finding and other courses I have been on cannot possibly cover all potential faults. I am therefore on a very steep learning curve learning as I go along. As I come across a fault I am more prepared for the next time. Companies are loathed to offer work experience because they assume at my age (30's) that I will become competition. Thanks again to all. Wilhelm - I assume you never had to learn or have help with training!
