Lockshield valve?
12 Jul 2013
London
I have an old radiator in the kitchen next to the fridge, which is understandably off, that I want to make sure is closed at both ends.
At one end there is the regulator (wheelhead valve?) so that's fine - that's obviously off.
At the other end there is a plastic cap. Under that there is a nut (well like a nut, but closed at the top - not sure what these are called - blanking nut/screw?). Undo that with a spanner and underneath in the recess is a screw. I haven't done anything with the screw. So far no water coming out.
What is this valve and how do I know if it is closed?
Quite possibly it is already closed, I just want to make sure.
Thank you.
sorry but your description doesnt really make sence ? can you post a pic and we will be better equipped to advise you
Sounds a bit like a Mk1 or Mk2 Pegler Belmont one-pipe valve or a Drayton.
Photo would be good, preferably in focus, and any branding on the valve.
Drayton LS with metal cap:
Remove cap, turn slot fully clockwise for off.
I wouldn't touch that screw if I were you! Those scredriver type lockshields are not known for their water tightness after they are disturbed :lol:
Don't touch it, by closing the wheel head valve you have stopped the flow so rad won't warm up.
thats why the have a tight fitting cap! (to stop the water leak after you have turned the regulation screw!) :roll:
Thank you all.
Before posting I searched the internet high and low to find this kind of valve, but couldn't. I knew you guys on here would know, and I thank you for the insight. So this is a lockshield/balancing valve. I am crazy and did a power flush of the CH system (ex. boilder) on Friday and wanted to isolate this radiator since it won't ever be used (if the kitchen is ever redone to include a radiator it would be a new one). In the end I don't know if it is closed on that side or not because I didn't want to mess with this screw (rightly so it would seem).
Thank you again for your expertise :)
P.s. Sorry for not posting a pic, I had already moved back the fridge, it was late and I was due to start the power flush early the next morning.
Yeah, obviously.
Why bother designing it properly in the first place, when you can just hide the problem.
