I want to start topping up the insulation and boarding the loft this w/e. From looking at these forums my current plan is as follows..
There are 3 main joists running along the house several feet apart that come up to 8in. I am planning to put 3x2 across these to bring up to 10in for insulation, then get some, say 18mm 1.8m long planks of some sort, so that each is supported at either end and in the middle by the 3x2.
Is this right?
Also should I be using planks or some sort of larger board, does this just come down to cost vs. ease of getting to loft etc.
Next what sort of screws should I be using? Do I drill a pilot hole in the 3 main joists for the 3x2, and then also in the 3x2 for the floor? How big and how deep are these? Do I drill clearance holes in the 3x2 and floor boards for the screws?
Sorry these are quite simple questions esp about pilot holes etc., not really done much like this before, but always learning. Just a bit worried about drilling into things I shouldnt.
Is this right?
