I noticed we have moisture in one corner of the bedroom, then i remembered seeing a lot of condensation in the loft.
My thought is that the loft insulation needs replacing anyway as it is thin and old.
If i insulate the floor joists with the relevant amout of "stuff" and use a system like Loftzones Storefloor that would help some of the problem.
Then, if i use the foam board insulation for insulating the roof and maybe even plasterboard it.
I will also have a couple of Servers and other bits running in the loft (yes geek alert) so there will be a bit of weight and heat from them.
Would be interested in peoples thoughts.
