Condensation in loft
20 Jan 2012
Merseyside
If I cross batton and compress the loft insulation and fit T&G B&Q loft floorboards.Will I get condensation under the boards due to the insulation being compressed?. There is insulation layed between the joist and some laid at 90 degrees on top of the joists.
No, you only get condensation when warm moist air meets a cold surface.
The insulation value may be compromised a bit but I guess you wouldn't notice......it doesn't compress as much as you think!
Keep the soffit area clear so the loft can ventilate though.
John :)
