Make sure you apply for building regulation from your local council before converting your loft into a bedroom and will need planning permisson if you raised or altered your roof.
The roof window or the dormer window is considered a means of escape, therefore the base or cill of the window frame must be a certain height from the finished floor and a certain distance from the gutter or the edge of the roof. There are an immense amount of blg. regs regarding loft conversions. Blg inspectors will advise.
