I bought a house with a large extension. The extension part of the house is prepared for a loft conversion ( suitable floor joist, veulux window, dorm windows, plenty of hear height), however the only place I can make access to the attic space is from the existing house due to room layouts.
One bedroom has already been partitioned off to I assume allow a stairs to be installed (currently my wives shoe room). It is quite narrow though, only approx 1.2m wide, reducing to 0.9m due to a chimney breast so I assume I would probably have to use a spiral staircase.
Anyway, in the attic of the existing part of the house the head height is only 2m in the centre, which is about 30cm wide, after which the roof slopes quite steeply (I would say 45 degrees). It has already been boarded out, however I will need to upgrade the joists in this area as the previous owner simply cross-battended this area to better spread the weight, as opposed to doing a proper job.
So my question is would this ever be building regs compliant, or will I only ever be able to consider it as a store area? How much extra height would I need to be compliant?
Also, does anyone have knowledge of spiral staircases? I am guessing I would need to consider the point loadings on the joists if I was to install one?
Many thanks for help!
