Loft Insulation and Eaves
5 Feb 2013
Coventry
Hi All
Had a bit of disagreement with a roofer today. Basically he had been asked to pull the loft insulation away from the eaves as they were blocking the eaves vents and causing a condensation issue in the loft space. The loft insulation was topped up to around 300mm about 12 months ago and since then the owner has always struggled with condensation within the loft.
There are no flues or possible lose ducting pipes which could add to the moisture within the loft space.
His argument was that loft insulation should be tucked right into the eaves to prevent a cold spot on the ceiling below and causing thermal bridging and a mould issue. He has a point but adequate ventilation and heating etc should prevent this.
Just wondered what your thoughts were on this.
I cut mine with a bevelled edge, so that it fully covers the ceiling, and reaches onto the inner leaf of brickwork, but does not touch the roofing felt. You can see daylight all round and the gap is a few inches. It can be done more accurately by cutting than by pulling back.
If the plasterboard was exposed, your roofer would be right.
I would also verify that the bathroom extractor fan is working effectively, and there are no holes in the ceiling, for example from downlighters.
