Having the roof of our dormer bungalow replaced so will be taking the opportunity to refresh the insulation. There is current access to the dwarf walls via a hatch, but it is crawling space so awkward to work in. I think the previous owner's electrician left the current insulation scattered and poorly placed, it also looks very old.
While the roof is being replaced, my plan is to remove the current insulation, give the loft area a good hovering a lay new insulation. The joists are 150mm deep. I intend to lay 150mm insulation and then cross it over with another 150mm. Total of 300mm.
I am going to rule out using rigid board as it will be more time consuming and more costly than the other 2 options.
Can someone please explain to me which is the better item > Mineral Wool v Glass Wool? To confuse matters further i have even seen some items labelled as Mineral Glass Wool?!
Any particular brand/model to go for?
Much appreciated.
Much appreciated.
