Loft light wiring Help Required Please
12 Feb 2007
Carmarthenshire
Batten lampholder wiring
Question deleted before I checked the replies, as I figured it out, but have another question regarding 'standard practice' of wiring, thanks
The wiki is a marvellous thing...
Davy
chris2006 said:
but unfortunately I can't find the pics
A likely story!!
Two reds in the loop terminals, black from mains to N and black from switch (sleeved red at both ends) to the L. Sleeve the cpc in G/Y.
Burger!!
Everybody beats me to it these days!
A true sign I'm getting old & creaky!
Damn! Such quick replies, thanks a lot! I've just had a cup of tea and figured it out - easy when you know how! so simple in fact, lol
I deleted the question without checking the thread thinking no-one would reply that quick, then I get a full answer, Wow!
Thanks a lot
securespark said:
A likely story!!
By the way - I have figured it out slightly different, but the same result, but from an electrician's point of view, should the red live wire from the mains be on the Loop, as you've suggested, or can it be on the "Live" screw terminal (as I figured it out)?
It's simple in that the switch just breaks the circuit between the Live and Loop terminals.
and PS. Re: the pics :) -- I've spent much of the day going through old DVD data disks, CD's and even recovered data from a formatted drive (and still doing so in the background!)
All the best
PS. Davy
I checked the Wiki and it's not the same as what you posted.
That's a good diagram, but this wiring assumes just one 3 core mains cable and not two, i.e. no "supply to next light", as well as a switch fitting with 2 lives and an earth.
All the best
Usually, I put the red/brown to the loop and the (sleeved) black/blue to the switched Live.
I have seen it the other way round, but that doesn't seem logical to me.
Thanks for your reply mate,
I get the idea of your post, but am unsure about the wiring reference you make.
There is no sleeved cable in this situation: just a 3-core flat grey mains cable I assume is wired up to the upstairs lighting, with a live (red), neutral (black) and earth (green/yellow) and another 3-core flat grey cable from the switch which is located nearby.
What I thought was logical was to have the Live wire from the mains screwed to the terminal labelled "Live", but you're saying I should put that to the Loop terminal and have the brown live wire from the lampholder to the Live terminal block, with the Live from the main on the Loop terminal.
Which is 'standard practice' do you know please, as I'm moving soon and don't want the new residents getting into any bother with the wiring.
Many thanks and all the best
The centre terminal in a rose are designed for the loop: the live wires. The others either side are meant for neutral (with three terminals) and the switched live (with two).
You mention 3 core cables later on, but in your OP, you only mention two twin & earth cables??
Hi there,
Thanks for your reply,
Maybe I didn't explain properly in the first question you refer to - it made sense to me, but I was writing it!
So I explained in more detail later on.
>> So the live from the mains should be on the loop, along with one of the switch red live wires, and on the Live terminal the brown lampholder live wire and another red switch live wire?
All the best
Sorry. If you've got twin red or brown, then yes, a red to the loop & one to the switched live terminal.
As you point out, the switch just breaks the live to the lamp.
