Not too sure if this is the right forum and I've read through the FAQ but this doesn't seem to be covered.
We recently moved into a new house that has had the loft boarded out with chipboard along the floor and eaves.
The lounge has a fireplace and chimney breast which has an unused gas fire. In the lounge I noticed a strong draft coming down the stairs and up the chimney. To the point when I shut the lounge door I can feel the air pressure and hear the air whistling round the door.
When I checked one of the bedrooms upstairs I noticed hole had been cut in the celing plasterboard in the airing cupboard. There is also huge draft coming through the surround of the door on the airing cupboard.
The problem with this is the hot water tank is also in this airing cupboard and I imagine we are losing a lot of heat up the chimney.
I did consider covering the hole in the plasterboard but then thought it may of been put there for a reason i.e.. for ventilation to allow air into the space between the roof boards and the tiles. I did also wonder if blocking the hole in the ceiling up may cause the tiles to be lifted in high winds????
To resolve this I was thinking of getting a quote from a roofer to add some roof vents so that I could block the hole in the celing in the airing cupboard leaving the roof space ventilated. I don't beleive the roof tiles are felted underneath.
I'd appreciate anyone's opinion on this.
Martin
Martin
