Hi all,
I have a log cabin built in the garden and am trying to get an electrician to come and wire up some electrics to the cabin. Who would have thought it was so hard to get people to respond to a job....maybe this is too small a piece of work?
Anyway.
I am slightly confused by the suggested approach by the 2 qualified electricians that have been round.
I had a shed before the cabin went up and this had a 2.5 T/E armored cable fed from a kitchen socket (8-10M long). We had an extension built and the electrician wired my shed up along with the new electrics for the extension. The shed only had 1 double socket.
The suggested approach for the cabin is to use this existing armored cable and fit a garage CU. Then from that have a radial circuit for the sockets that i need for my office. Around 4 double sockets to feed laptops and computers, monitors etc. Plus either a 2 KW heater or small air con unit. Lights will be Plugged in so no need for a separate circuit.
Both electricians advised that this would be OK as there would be a 20A breaker in the garage CU which would protect the cable to the house. Which then joins a 32A MCB ring circuit.
The reason why i am asking whether this sounds OK is i have read other forums where electricians have been frowning on this very setup.
What concerns me more is the fact that before my cabin went up i laid a patio/ slabs all around my house. Before doing this i laid proper conduit following regs to prepare for the electricians to run a SWA from the cabin back to the main house CU. Did i really dig that 20M trench for nothing?
Now i am not the certified electrician so who am i to question their proposal? well a concerned, not so daft home owner that's who!
Incidentally neither have come back to me for any availability or dates when this can be done, so I'm pondering if i should be seeking a 3rd opinion.
I would appreciate your advice.
Joe
Anyway.
Joe
