Logik L612WM13 - Washing Machine Drum Bearing
26 Mar 2010
Worcestershire
Hi All
I have the above washing machine and it is obvious that the drum bearing needs replacing. Am happy to try and do this myself cause the machine owes me nothing and if it is unsuccessful then at least I will have it in bits to take to the tip!!!
The problem I have is that the likes of espares and partsdirect say they cant supply me with a replacement bearing but as this is likely a similar size to that of another manufacturer model I can get the part if I know the size.
Whilst the machine works albeit very noisily I am against taking it apart as ordering the part could take a while so if anyone knows what size bearings are required for this then your help and advice would be most welcome
TIA
Ian
10 Mar 2007
Poole, Dorset
You are assuming the bearings can be replaced - many washing machines have the drum bearing moulded into the plastic outer drum, so replacement isn't possible. Only option is a drum assembly, or in reality, a new washing machine.
26 Mar 2010
Worcestershire
Good point. Going to be a gamble :)
