Long concrete screws
13 Nov 2020
Looking to attach 50mm PIR through 75mm battens to our 215mm solid brick wall. So looking for a conc screen at least 250mm long. Can anyone recommend any?
Why can't you just fix the PIR to the battens? That's what I did when applying PIR to the walls.
You could then use insulation washers (eBay) to hold the PIR to the battens, using normal screws.
250mm screws will be expensive and probably something like deck screws.
I'd prefer to keep the battens on the "warm" side.
Are you fitting plasterboard over the top?
wall, PIR, battens, PIR infill, cross batten (service void), then PB.
You could use 2 x 1 as the batten instead, 12.5mm plasterboard + 25mm batten + 50mm PIR + wall? 60mm... so a 150mm wood screw would do.
Sorry, started before saw your post.! infil etc
good point: Im confused by the need for 75mm battens
50 x 25 is strong enough -maybe 100 x 25 for radiator brackets
if you want more insulation -do that in the first layer, then 25mm battens over
or is there a reason you need an extra stud wall
I'm aiming for 125mm of insulation, so whether the infill is 25, 50 or 75mm the total depth to secure would remain the same?
No particular reason for the cross battening. If I was to stick 125mm PIR to the wall and then batten to be used as the service void too, I'd actually need to screw into 125 + 25.
ah ok
Ive not seen any concrete screws over 200mm
you might get away with 50mm into the masonry, so 200mm screws is possible if you counterbore the battens so screws sit down by 10mm
I would "resin" in some threaded bar and "impale" the insulation onto it followed by the battens. Long concrete screws blind into a wall would be hard work trying to hit the centres of the bricks etc.
