Looking for 4-way 250v rotary switch
I was thinking of a photo of the broken switch and the plastic mounting assembly.
Well, the switch isn't broken as I said earlier. It's the plastic mechanism.
Much as I appreciate your helfulness, I'd have to unmount it and take it apart again to do that. Last resort, I think, if I can't find an alternative solution.
To be honest, I don't think it's repairable since the operating slide is moulded into the fascia. The whole fascia would need changing and that puts the cost out of court - getting close to a new hood price!
A switch like the one you posted a photo of would cost more than a cheap cooker hood. Try freecycle - join your local group, ask if anyone is throwing out their cooker hood. I often see complete kitchens on there.
Or take a multicore cable(s) to a position on the wall and use normal switches for the fan, lights etc.
That switch is offered at £6.28 delivered!
"Normal switches"? However you do it you still need a 2 pole, 4 position, BBM switch! May as well mount it on the canopy if you can find a suitable one :)
But what connections are made and broken at each of the 3 positions?
Well, at the first position the fan is off.
2nd position: the contacts connect to the low speed coil of the fan motor.
3rd position: the low speed contacts are broken and the 3rd contacts connect to the medium speed coil of the fan motor.
4th position: the medium speed contacts are broken and the 4th contacts connect to the high speed coil of the fan motor.
