Are you able to identify at the light with 4 cables; which cable goes to the switch, and which cable goes to other light in the same room?
True, but are you suggesting that live testing should be undertaken to determine which?If you disconnect all cables, you should only have one cable that is permanently live.
I'm struggling to understand how one could get that functionality without some very strange wiring.Both lights are controlled by the same switches (there are 3 in the room) and both lights should come on at same time. Currently the way it's wired (if I attach both lights) one comes on while the other is off and switching any of the switches turns the one off and the other on.
So I have 2 S/L wires?
diagram linked in earlier post still only has 3 cables shown so not clear how I wire up 4th
Hi
The first has 4 cables. I've tried following the diagram in the link below as a guide to how to wire it, but its not worked.
http://www.diy.com/diy/jsp/bq/templ...ow_to/fix_ceiling_light/fix_ceiling_light.jsp
Shouldn't that be the FIRST diagram?Your wiring should be like the second diagram, only with an extra fourth cable. This fourth cable goes to the other light in the same room.
Both diagrams have four cables.The fourth cable gets connected to the 'flex to light' terminals (switched live and neutral).
This ensures both lights come on together.
and..The second light in the room was simple; there is one cable from the ceiling and I could directly wire into the new junction. The first has 4 cables.
If (as should be the case), there is just a single cable connecting the second ('slave') light to the first, then I can't see how the described behaviour could happen unless there were (obviously 'unconventionally') three (or more!) cores coming from the switches to the 'main' ceiling rose. Otherwise, how on earth could there be power being supplied to the second ('slave') light when the first light was 'off', but not if the first light was 'on'? ... or am I missing something 'obvious'?Both lights are controlled by the same switches (there are 3 in the room) and both lights should come on at same time. Currently the way it's wired (if I attach both lights) one comes on while the other is off and switching any of the switches turns the one off and the other on.
GoodI've identified the wires:
Right.I have 1 main supply wire - test using multimeter on AC setting
So, one not identified, then.I have 2 wires giving residence on multimeter. One was labeled the switch live with brown tape, I think the other goes to next room.
So, a second not identified, then.I have 1 wire showing neither reading which I believe is the wire to the second light in room.
Not, though as originally wired when it worked.Wired up as advised. Same problem as reported originally with one on one off.
I'm afraid the only way is for you to learn and understand how the circuit works and how to test to be certain - or an electrician.Really appreciate some help!
