I've got some loose brickwork between a bedroom and bathroom window.
The walls on the inside are bare brick and solid.
I'm thinking the wall ties might have failed so plan to pull that section of wall down and rebuild it. Which wall ties should I use when building it back up?
I've seen these at Toolstation which I would guess were the right ones but thought I'd best check:
https://www.toolstation.com/shop/Co...ainless+Steel+Screw-In+Wallstarter+Tie/p63017
