using redland regent interlocking tile on 12.5 degrees pitch had roof on once bco not happy checked roof 9% in some places as low as 6% started again but losing pitch within 2 rows of tiles can anyone help with geting started
OK, the tiles themselves will have a pitch slightly less than the rafters, due to the overlap of the tiles...Hi,
The pitch of the tiles will be less than the rafter pitch by a few degrees, but it should stay the same all of the way up the roof.
In my opinion 12.5 degrees is far too shallow for most roofs and should be almost considered a flattie dressed up as a tiled roof.
What a lot of people do not realise is that a 12.5 degree roof would only be suitable for the simplest of lean-to designs.
If you were to start introducing things such as valleys, dormers, roof lights, sun tunnels, etc into such a shallow pitch roof, then you are asking for trouble.
The shallower the pitch the greater the care when battening/felting/tiling the roof.
