    Dismiss Notice
Loss of pressure in Combi boiler
Discussion in 'Plumbing and Central Heating' started by Kantilal Tanna, 23 Mar 2015.
  1. Kantilal Tanna
    Kantilal Tanna
    30 Jul 2004
    45
    Thanks Received:
    Country:
    We have loss of pressure in Combi Boiler and stops working with a red light.
    We had heating Engineer who changed the diverter but the problem still remains.
    I have not noticed the fault code but I think it is F75.
    Can anybody kindly suggest what may be causing problem?
    I read several articles in forum but unsure what to do. Can anyone suggest an Engineer around Barnet area and how much would it cost as I have already paid £180. for just putting Diverter.
    Many thanks.
    Tanna
  2. Sponsored Links
  3. TeaTime
    TeaTime
    21 Jan 2015
    362
    Thanks Received:
    47
    Kent
    Country:
    Boiler make and model please.
    I assume you are noticing a full pressure drop on the pressure gauge on the front panel, not just a loss of half a bar?
  4. Tibbot
    Tibbot
    27 Nov 2009
    2,037
    Thanks Received:
    349
    Herts & Essex
    Country:
    How much will what cost? This isn't a clairvoyant's forum.
    • Thanks Thanks x 1
  5. Kantilal Tanna
    Kantilal Tanna
    30 Jul 2004
    45
    Thanks Received:
    Country:
    Vailant ecoPro 28.
    At present when I press - key it shows 1.6 and gauge is middle of green.
    Hope this makes sense!
    Thanks[/b]
  6. Sponsored Links
  7. TeaTime
    TeaTime
    21 Jan 2015
    362
    Thanks Received:
    47
    Kent
    Country:
    So the pressure on the gauge seems fine but the boiler is in lock-out showing an error code of .....possibly F75?
  8. Kantilal Tanna
    Kantilal Tanna
    30 Jul 2004
    45
    Thanks Received:
    Country:
  9. TeaTime
    TeaTime
    21 Jan 2015
    362
    Thanks Received:
    47
    Kent
    Country:
    Sounds like the expansion vessel needs refilling / replacing IMO, but there might be some additional issues, which the boiler engineer will look into.
    Not sure about the cost, but others can advise.
  10. Kantilal Tanna
    Kantilal Tanna
    30 Jul 2004
    45
    Thanks Received:
    Country:
    Hello, once again, the Boiler Engineer came back and filled expansion vessel with foot pump but after a while water was still dripping outside the wall and he replaced another valve, probably PSV, it worked fine for half a day and same problem occurred. Showing red light, increased the water level twice, it worked fine for few days and now have same problem, though pressure stays in middle (green area). Do I need new expansion vessel? Or there is something else.
    Any help will be highly appreciated. Thanks.
    :unsure: :unsure: :unsure:
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
