Lost insulation and name for material
11 Oct 2018
What is the name for the ripped material under the slats please?
Would the insulation go under the ripped material and could it be patched up?
Thank you
If you have original photo select...
Attach files .... Bottom left here and upload so we can see. That photo is poor so hard to see properly
Hi @Wayners, here is a bigger one things. Interested in the ripped/missing thin lining under roof beams/slats. Thank you
Sarking felt I think.
Decide for yourself from this article.
You can't repair from the inside. Spray foam is controversial and is used from the inside.
That is a new word for me!
If you cant fix it from inside, then it sounds like a lot of work to do it and it may have been like that for years or decades without an issue. Yes, it came from a survey.
Is it worth just putting insulation wadding in the gaps between without fixing it?
Thank you
