Lost Key
22 Mar 2007
Cumbria
Have a back door unlocked and the key for the euro lock has been lost.
Without a key how do I remove the lock.
Obviously with a key the job is easy but without I can't turn the lock slightly to pull lock out.
Help!
Get a locksmith in, honestly it could save you a lot of money in the long run. Breaking or drilling these cylinders can cause havoc with the gearboxes,rods etc. for-bye locksmiths have all the tools required to do this quickly and without damage...pinenot :)
What area are you in?
if you need a locksmith the Manchester area locksmith in Manchester
or to find a licensed locksmith the Master Locksmiths Association is always a good bet nationally www.locksmiths.co.uk
there is alot of info on the internet regarding the removal of euro cylinders with out the key, they are designed to stop unauthorised, non key holders changing the cylinder. It is easy to distort the delicate lock case, and costing you more in the long run.
good luck!
