Can you help me cure my noisy central heating system?
There is a rushing sound in the pipes when the pump is running and the pump seems to make more noise than it used to. Also when the motorised valve operates there is a very loud banging coming from the pipes.
The heating works ok and there is no air in the radiators. There is a bleed screw on the top of a vertical pipe in the airing cupboard and this collects a little air behind it every few days.
This problem may coincide with the fitting of TRVs I drained the system down and fitted them in the summer, the noise started this winter the system uses microbore pipe.
Are all the noises related?
Help please its driving me crazy!
Thanks in advance,
Jon
Thanks in advance,
Jon
