A relative of mine has put LE bulbs in Two of the upstairs lights. One of the lights is switched using a Dimmer. This is why the lights have been flickering. Changed bulbs back to original,but none of the upstairs light are working. Could putting the Low Energy bulb in have caused the Dimmer not to work at all now? Will also check to see if the CU is split and the RCD on the lighting side hase tripped. Also any loose connections.
Is there anything else I could check for?
