Low Energy Bulbs and dimmers
17 Oct 2006
Could someone please explain why they are not compatible?
I had low energy bulbs nearly everywhere in my last house but, when I moved recently, I found that most rooms have dimmer switches. So I am stuck with conventional bulbs. The cost of low energy bulbs is high enough without the cost of replacing all the dimmers!
Incidentally, why does the light output of a low energy bulb never seem to be as great as is advertised? For example, a 20W LE bulb is supposed to be the equivalent of a 100W incandescent, but you only have to put them next to each other to see that the LE bulb is dimmer than the incandescent.
The varilight dimmer and switch operated ones state a smooth transistion from 2% to full brightness not stepped.
Hi, trying to find energy saving bulbs compatible with old dimmer (that won't produce buzzing). Any advice would be much appreciated!
Done. Just comes up when you enter title...
