LOW HOT WATER PRESSURE
26 Apr 2007
Devon
Hi all,
I'm in a large Victorian house which suffers from low hot water pressure at the taps. The cold water pressure is adequate. Mixer taps are a nightmare, when turning the cold on it almost completely overpowers the hot. Gravity showers any distance from the water tank are a nightmare. I assume most of the problem is a result of long runs of old copper pipe, (God forbid! I even found a bit of plastic pipe the other day!), which is too small (15 mm). Other than a complete renewal with 22mm pipe is there anything else I can do?
Yes, pump it, or use a mains pressure hot water store, mains pipe permitting.
are the mixer taps (and showers) you have designed to work on a gravity system? if not that will be making your problem worse
