low pressure at hot water taps
10 Apr 2006
Glasgow
hi folks, new here so be gentle.
ive got a vokera combi-boiler, which seems to work fine and dandy, rad circuit is ok, needs topped up occasionally but nothing to worry about.
the problem is my hot water taps, bath, wash hand basin (upstairs) and kitchen (downstairs).
as soon as they are switched on the pressure behind it would just about blow you away, but within a couple of seconds it fades to not much more than a trickle, and it has got to the stage where filling a bath is taking over half an hour. i think that while the taps are running, and just after they have been switched off i can hear air gurgling through the pipes.
is this what is causing it, and so how do i rectify it??
billyl81 said:
nice try but up here we dont even have to worry about that stuff
Ah...the soft peat enriched water of the burn, turned into many a fine Single Malt :wink:
Check square looking inlet valve on right hand side underneath boiler is fully open.
If fully open then restrictor is blocked.
Right hand rear connection to heat exchanger has a restrictor - either clean out or remove the center piece and O ring.
do i have to ope up the boiler to get into this connection gasguru? as i cant see a rear connection just now, just 5 in a line
Front panel has to come off to get to pipework.
You may want to consider getting a boiler engineer in to repair as you don't sound to confident in diy boiler repairs.
Should be a 10 minute job plus safety checks.
gasguru, thanks for the help, havent been able to get back on here in a while. pipework im ok with if thats all it is but i suppose i'd be better getting someone who really knows what they're doing, are
there any regulars on here from the glasgow area??
