Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I am laying my blocks flat over a 10m run holding back roughly 300mm of soil.
How deep should my trench be and how deep should my concrete base be?
On the width I have gone for 415mm in the base.
100mm ish concrete footing for small walls in stable ground is adequate. No need to over do it - it’s hardest holding anything back. With laying bricks flat too it’s going to be already a pretty heavy duty spec for just 300mm of soil.
