Low voltage halogen lights blowing 13A FCU
21 Nov 2010
Cheshire
I have been trying to get my bathroom lights working all day and drawn a blank. I had originally wired a transformer into the ceiling rose which was powering 5 x 20w halogens, plus a socket thawould sit in the loft space and allow me to plug in 4 LED's that would sit below the bath. They seem to work fine for a small amount of time and then the 13A fuse in the FCU will blow. They can be turned on and off a number of times before blowing the fuse at random intervals.
I have now tried witing the LED's into the transformer which I have read on here is incorrect I think and reverted to having just the 5 x 20 halogens but yet again the 13A fuse has blown. There is also a ceiling fan which is connected to this FCU but is very rarely used so not sure if this bears any relevance.
The system is in a fairly new house with a consumer unit using B6 MCB's for the lighting main, the MCB never actually goes when the fuse goes. The lighting on this MCB is well below the limit also.
Any suggestions?
Thanks in advance
Gareth
What 13A FCU? you only mention a transformer and a socket, wired from a ceiling rose? :?
