Low Voltage Lighting Problem
Dunno.
Remember, they aren't transformers, they are switched-mode power supplies.
They have a transformer in them, but the primary is not connected to the supply.
I would suggest the transformer you have are not a good make, also suprised you have some individually on their own transformers and others shared, be careful not to put high wattage lamps in the shared ones.
I would recommend three manufaturers tx and would not consider any others
Mode
IBL
Aurora (higher end not their cheap range)
Stick with these and rarely you will get a problem, unless installed incorrectly
