Hi
I want to put in four 50w lights on a twin wire suspended cable system, and have been advised by a lighting supplier that as I wish to use 6.5m spans I will need 2 x 300w Toroidal Transformers. This seems a bit over the top as Ikea sell a set to cover 9m with a single transformer?
Can anyone advise me if I do in fact need two transformers? If so what is the reason and how do I connect them do I connect them in parallel and do they have to be alternate ends?
Is there any maximum cable length from the transformer to the lighting feed cables.
Can I use the same cable as I am using for the spans to feed them or does this cable have to be a larger diameter?
I was looking to use a 6mm cable for the spans!
Hope this makes sense?
KB
KB
