A puzzler (for me at least!)
The lighting circuit in my bungalow insists on leaving an odd (low) voltage on the positive wire when it is switched OFF. All sockets and other circuits have no problem. When lights are switched OFF, the positive line shows a consistent, but different voltage for each room - from 6 volts on spots in the living room (and 27 on the main light), to 45 volts in the kitchen. Even odder, is that the spotlights in one room (where the main light has 21 volts when OFF), are the only ones in the house with ZERO volts when OFF.
I have checked this with ALL other circuits OFF at the main box and the problem is the same, so it is not induced voltage from another circuit. It would be a great help in avoiding ripping up the whole of the roof insulation if someone could suggest what's going on here. Is it a dodgy switch? There are three dimmers in the lounge, but the voltages are not altered by adjustment of these, so don't appear to be the cause.
I have thought about splitting the loop at 'half-way', then 'half again' to pinpoint the cause by elimination. Is that a good idea or not?
Any help appreciated.
Regards,
Mathew
Regards,
Mathew
