No need to apologise. That supplier clearly has no idea what he is talking about. He refers to those lamps as MR 16 when they don't have a multifaceted reflector. He also refers to them as low voltage which we all know is wrong as explained in post 2.
Hi Winston1,
I felt compelled to get involved when you called me out, I happen to be the owner of the business (LEDSmiths.com) and you claim that I don't know what I'm talking about. As the website is a website that faces the general public that aren't electricians or lighting professionals, yes we have terms such as MR16 (Multifaceted Reflector, 16/8ths of an inch diameter) on the website to describe what the general public need to know to replace the lamp that they would be holding in their hands. I should know, I also worked for a major UK manufacturer and designed the lamp stamps that went on to the old halogen lamps. Not only did I spend time working on the halogen lamps you would have worked with in the past, I then moved onto being the LED Development manager of this particular company and designed and specified the LEDs that hundreds of thousands of people now have in their homes.
So what would you call it? You can't call it a GU10, because that would be wrong, GU10 refers to the base of a GU fitting that is 10 mm apart (you might have seen it as nail heads protruding from the bottom of the lamp). You can't call it a PAR16, because that in your eyes (you've already poo-poo'ed MR16), stands for Parabolic Aluminium Reflector, 16/8ths of an inch diameter. Can you just call it a spotlight? Or is that far too generic because that could refer to a PAR10, a PAR16, 20, 38, 56 or an R39, R50, R63, R80, R95 or R125 or a GU10? No the only thing to describe it to the general public for them to understand because they are holding in their hands and reading the lamp stamp is MR16 and I do apologise if this doesn't live up to your high expectations but as I've also (before my LED Development days) ran one of the leading online lamp retailers for 8 years, every person that doesn't understand lamps calls these particular 'bulbs' (note I'm using the term bulbs, shock horror!) MR16 and any voltage that is lower than 240V is then also called 'low voltage'. Again I apologise that this might not meet the high standards of electricians around the country but in order for the public to receive the correct LEDs they need 'laymans terms' to make sure they land in the right spot.
Back on the topic of the discussion, what securespark mentioned is spot on.
