Hi, Im in the process of converting my Garage into another room and need to add an extra socket and lower an existing socket. In the garage there is the fuse box and an existing socket which is part of a ring curcuit. In order to lower the existing the socket I'm planning on adding a 30 amp junction box in the loft space and then run a new spur to replace the existing socket. I'm then planning to use the same method to add and additional socket into the room. As i'm adding a spur to an existing ring curcuit am I correct in thinking that under 'part P' I (none qualifed electrician) can complete this work.
I would appreciate if somebody could confirm if this sounds ok or let me know if their is a better method.
Many thanks
Many thanks
