Hi
Moved into our house a year ago and electrics were fine for 4-5 months and then the RCD tripped. By a process of elimination I concluded it was the lower ring that only supplies are dining room and one external socket that was tripping the RCD, so by leaving the 'circuit breaker' for that ring 'Off' I could turn the RCD back on and the electrics in the rest of the house work fine.
I removed all devices from all sockets on the ring and turned it back on and within 45 minutes it tripped again, so it has been left off for the past few months as the problem must be in the ring wiring somewhere.
Time has finally come to try to work out why it is tripping and see if it is a DIY fix or I need a sparky.
The ring is switched off and we have removed all the socket covers and cleared out all the dust that was in there. We have done some basic continuity checks and there is continuity between the earth and the Neutral which doesn't sound right to me...but wanted to check with someone who would know for sure before we try to hunt down where the short is (if there is one), I can't think of any work that has gone on (suuch as nails into walls etc.) that might have caused it though?
Thanks in advance
Rob
Thanks in advance
Rob
