Lowering the ceiling height
7 Oct 2013
Hampshire
Part of newly build extension, faced with this dilemma:
We are removing external loadbearing wall and naturally putting a beam across. For new ceiling we have two options, either we box the beam and keep the ceiling height same or lower the ceiling level and have straight ceiling across the exiting area and the new extension. Lowering the ceiling will bring the height down to approx. 2.5 meters.
Unsure what would be advantage/disadvantage of the above so appreciate your input!
cheers
Aside from the cost of installing a false ceiling, it's an aesthetic issue and only you can decide whether or not you can live with a downstand beam.
Spot on Tony, yep we are faced with aesthetic issue and i guess we could not be the first or last to go through this, hence the reason for the post to hear from others what they choose and why?
cheers
Agree with Tony, your choice. Cheapest way is dropped beam with Expamet Arch Former each end to give it a bit of character..
Regards oldun
Regards oldun
Hmm character! And some ducks on the wall too and why not add a bit of Artex whilst you're at it! :P
Good idea that Freddy. You could also have Flanagan and Allen round, though suspect they were a bit before your time. Are you still leaning out your window to see into your neighbours hot tub?:roll: :D
Regards oldun
__________________
Cats Rule!. Not according to my dog.
Leaving humour aside, the message I am getting that its best to lower the ceiling, giving ceiling a consistent look?
