A couple of queries regarding LV downlighters. I plan to fit 5x20w units in a boxed shelf above a bed, between wardrobes. Shelf material is chipboard, gap between shelves (void) is just 65mm.
1 Will these things run too hot? Would vents at each end (into the wardrobe) help?
2 Can they be fed from a ring main socket? Would they need a seperate fused connector, or would a smaller fuse in the plug be ok?
3 Would it be better to take a feed from the lighting circuit in the loft, and if so, why?
4 Am I right in thinking that this is non-notifiable re Part P?
Thanks in advance...
