Macerator discharge
25 Sep 2011
Hampshire
I'm remodelling the downstairs layout of my house. This includes knocking through a utility room to form a bigger kitchen diner and relocating the utility room.
I intend to add a toilet with a macerator in the utility room.
In terms of discharge from the macerator I guess it would be normal to use a strap on connector to the soil stack. Given the layout of the house this is not very practical, but I do have an old washing machine waste pipe available which could be re purposed. Is this allowed under the regs?
4 Oct 2012
East Renfrewshire
As long as the washing machine waste is running to a foul water soil stack - which it should be - then no issue with using that.
Just remember to use the correct size adapter so the pipe work from the macerator is properly sealed to the larger washing machine waste pipe.
3 Nov 2006
Bedfordshire
Take advice from the Building Control Officer, the advice is free,
Even if it is allowed then consider the effect of a blockage, the positive displacement pump in the macerator and a weak joint between pump and the blockage.
If it is the only toilet then it CANNOT be used with a mascerator.
25 Sep 2011
Hampshire
Thanks.
The upstairs toilet will still connect directly to the stack.
I guess if I reuse the old washing machine waste pipe (with suitable connector) then I still need building control to inspect the new toilet installation?
3 Feb 2008
Northamptonshire
You are aware of the limitations with macerators, and the unpleasant consequences when, (not if), they go wrong I presume...
Is there no option for a 4" soil run from the new WC position before you go down the macerator route?
26 Jun 2004
London
Are you even aware that new toilets need Building Regulations approval?
Normally done in advance with drawings and a fee ?
Tony
26 Jun 2004
London
Er.... no!
Drawings and a fee to get approval.
Then normally an inspection when completed to make sure its fitted in accordance with the approved drawings!
Jobs for the boys!
Trouble is that many cowboy builders and DIYers dont do them correctly.
So the councils need to control them and they of course see that as an opportunity to charge!
Tony
