Hi
Just been asked to move a bathroom, we will not be able to get a fall on a 100mm soil pipe so the only way is to fit a macerator. The problem being the bathroom will only be wide enough to fit a WC and bath side by side and the basin at the other end of the bathroom.
|Having only ever fitted one macerator before, can I put a Y tee onto the pipework downstream from the macerator, just thinking its pumped sewage and don't want problems with it being pumped up through the basin waste, obviously fitting tee facing up stream or will I have to run another pipe just for the basin. Floor space is tight.
