MagnaClean Installation
31 Aug 2012
Berkshire
Hi guys,
New here and was just wondering if you could give me some advice on installing a MagnaClean on a 22mm unvented system.
I'm a little bit unsure on where to install as I don't want to install it straight after the pump and my boilers mounted to high to place above. I've enclosed a picture for you guys to have a look.
Should I be covering the cylinder and the radiators or just the radiators?
I'm an electrician by trade so I'm useless at plumbing, any help would be much appreciated!
The usual practice is to install the magna clean on the return pipework as close as practable to the boiler if space is restricted by the boiler I would suggest putting it on the pipework directly to the right of the Grunny pump at low level  8)
Amazing, no insulation but someone has bothered to paint it all silver.
Must be a new build.
Its alright, a bit of ptfe should fix it ;)
You may well be right, PTFE is very good for sealing certain joints, as I know from personal experience..
However I'd rather have a device that is better made and doesn't leak.
How many have you fitted? How many of those have leaked? How many of those are now caked in PTFE?
Not particularly interested in getting into a slanging match again - the last one was never finished anyway... but if you are going to start giving this sort of advise based on "experience"- can they be real numbers rather than made up percentages ;)?
so litterally just after the return pipe from the cylinder?
I cant see a htg in return in the airing cupboard is there one ?
Sorry not very clued up when it comes to plumbing.. htg?
