Hi All,
I have tried searching for a fix for this problem before posting this, but was unable to find one in the forum. It's my first time on here, so i'm sorry if I've missed any forum etiquette. Maybe you can help?
I have a Main 30 Eco combi boiler that was installed about 2.5 years ago, and doesn't get used heavily - (only 2 adults and 1 child in four-bed house) so fairly new.
When it was installed I had all the central heating installed new too as refurb'd the whole house.
The boiler used to lose pressure after several months at first but progressively this has got more and more frequent. Within the last month or so it has gone from once or twice a day, to now lasting about a minute til it all drains away.
I have checked the PRV copper pipe and that seems fairly dry - no signs of dripping.
I have checked the radiators and none seem to be leaking.
None of the pipe work shows any leaks (though the kitchen pipe work is concealed in a wooden box underneath the wood flooring so not visible).
However I did check by closing the isolator valves and it still just drains away.
The water still runs clean at the taps.
I'm not averse to paying for a plumber to come and visit but the two I have had so far seem just as confused, so I was hoping you may be able to help?
One said we "could start by changing the domestic heat exchanger, and see if that does it, or then try something else" which didn't fill me with confidence. Another said that he'd try inserting food dye in the system to identify the source, but said that he wasn't sure either - hence my post.
Is there anything I can try to help identify or diagnose the problem - I have little knowledge of plumbing but can follow instructions!
just want to know a little at least what I'm talking about before getting a THIRD plumber in.
Thanks you in advance for your help, I really appreciate it. Please ask if I have left anything out.
Fez
Fez
