My central heating uses a wall mounted Glowworm Fuelsaver 30B Mk2. It's given years of sterling service but a fault has appeared. When the boiler thermostat calls for heat, the gas valve solenoid clicks and the main burner lights perfectly with the correct-sized flames. But within 1 second, the flames die right back producing 'soft' flames which barely cover the burners.
I measured the solenoid volts as 22.3VAC
I tried tapping the gas valve and this seemed to fix the problem, but a day later the fault was back.
Any thoughts please ... Richard
