BS 7671 does not specifically prohibit the use of two conductors for this purpose, although it doesn't recommend it. However, you must a) ensure the mechanical integrity of the earth cables and ensure they are labelled clearly b) prove that the current carrying capacity of the two cables meet the minimum requirements of your installation. If you're adding a cable to your existing, I would recommend you use the correct size cable and disconnect the existing.
